My bed is too tiny?
In Easel, go to the machine inspector and type $$. That will give you your grbl settings. The X axis steps per mm is stored in the $100 parameter. Y is $101 and Z is $102
Lets say your setting is currently 250.000, you try to jog 50mm and it actually moves 12mm.
Expected/actual*current steps per mm = your new steps per mm.
So, 50/12 = 4.1667. That times 250.000 = 1041.667.
You’d enter $100 = 1041.667.
Repeat the tests until you get it dialed in. I’d jog as far as you can, and make sure you are measuring accurately and precisely.
