I’m new. That’s a starting point. haha. Two part (may turn 3 ) question instead of flooding the board.
I have attempted 3 boards. One came out AWESOME.
The other two, stopped mid way through.
Board 1, int stopped mid way through and was just sitting in one position for a long time before I realized it had stopped. Still have 45 minutes of carving left but I couldn’t get it started again.
Board 2, randomly stopped and went to home position.
Soooo… Question 1: Is there a way to re-start the carve, either without having to carve the entire thing again (meaning it would be carving air) and in restarting, how do I get it to start in the perfect spot again? I tried use previous starting point and the mill didn’t even come close to touching the wood on one, on the other it started a couple mm off course.
Question 2: I used a straight up mill for the rough cut and wanted to use a V mill for the detail cut but it was not leaving very clean deep cuts.
Question 3: did either of those two questions make sense?
Question 3B, is there a way to have the router turn itself off when it’s done so I could go to sleep at night hoping it all works out?
Thank you.
