my x carve didn’t cut more than 2mm i tried all slotion and i think its some wrong in g code ($000) that controling z axsis can you help me
Can you jog the Z axis up and down without issue? Does it move the amount you tell it to?
How are you setting Z zero?
Can you share the gcode?
1- no it move less than 10mm i Measure it move 1mm
2- manually
3- now i cant but i will share it when i get back to my workshop
No, that is not gcode - that is your GRBL parameter value list.
Still relevant for your issue I suspect but we need to clarify a thing first:
- If you command a 10mm jog on Z up or down, is the measured distance = commanded distance?
no its not , I measured it and its goes 1mm
Does your DIP switch for the Z match the one below (I would recommend turning 4 off on all, but that’s for a different reason). You should have 1 & 3 OFF and only 2 ON.
Then your microstep settings and $102 value need to be adressed as there is a mismatch.
What is your machine? Xcarve, 3018, or what? This will help determining where to look at first
