OK, I have been away for a while and I cannot figure out how to combine an item from the art library. I have a file showing two sandals. What I would like to do is move the sandals together such that both sandals exist as one outline to cut. I have had no luck editing and I am at a loss. Any tips, tricks, or advice? Thanks in advance.
If they both are one selection when only one is clicked. Then use the Xploder or Shape Exploder app by selecting Lego button, then once they are seperated into individual pieces you can move then combine.
If this doesn’t work. Can you share the project and I’ll make a short video showing what i mean. Simple Method - How To send a friend your Easel Project - YouTube
Not sure if this is the outcome you were looking for. If you happen to have a sample photo of the desired outcome, I can re-do this and show/tell how to get the desired outcome using Easel…
Here is a link to a project that might show what I want to do. I did a freehand since I couldn’t figure out how to post an image to the forum. Thanks.
Thanks for your help.
