Looking to make a quick cake topper for my wife’s business and i am having an issue putting this easel pro design merged with a stick (to go into cake). Is there a easy way to join them so i can carve them both as one object? ive tried joining them but it still cuts out the full heart.
link to the project here…Easel - Untitled
thank you!
Your outside line of the heart is doubled up. Move the top one around and you will see. If you delete one, you can them combine the stem with the heart.
Remove the extra layer
Select all
set to Clear out pocket
move your stick up into the heart a bit
Go to Edit combine
then set to cut on path
What Steve said
I also make such items on occation:
