Need help please
I need to cut this out but dont need the top part of the design, i just want it to cut straight through on the top as if i were going to continue cutting if i had tiling option. i dont know how to erase only the top of the design.
http://easel.inventables.com/projects/wF4ih36xHIU8efb7Lb6i-Q
you can make a box that covers the part you dont want cut and set it at zero
Make sure that you bring your box to the top. Under edit, bring forward.
… and set the box to a 0 height
Thanks for the suggestions, I’ll give it a try tomorrow.
Hey guys just wanted to let you know the box idea worked out. Thanks again!
