I need help I don’t know how to set up a file so that the design stands out on the back board. or what bit to use… I need it to be as big as I can make it…
Hi April,
what you need to do is select all. then deselect the most outer vector.
use the pocket cut path, use the most outer vector for your cut out.
you get something like this
oh wow that is awsome now sounds easy… lol I have not used this program that much so I hope I can get that. Not good with vector files.Thank you i hope i can get this right i think it would make a great gift.
