Need help with this project
DFLTU12_M-Piercings-Tunnels-Plugs-Double-Flared-Tunnel how can I get this to cut the outside into easel
I assume you are referring to the OD that is recessed?
I don’t think the tool path can be done in Easel.
With Vectric V Carve and a slotting bit it can be done using lead-ins and lead-outs.
Never got the hang of F360 but it could likely do it as well.
can I confirm you just want the shape cut and none of the detail?
http://easel.inventables.com/projects/R9OxmlzdkObK-hnFedQO_A
Wanted the curved outside to or I wonder what took to use to get the curve
cut out a circle with the hole find a bolt that will fit on and clamp it with a nut then put it in a drill press and shape it with some files
Cool thanks
