I’m cutting mortises in 3/4" Oak and would like to make the final pass at 0.78" to be sure of clearance. In the “CUT” window it’s only allowing 0.75" Is there a way to extend the depth of cut allowed?
Yes. Lie to the software and tell it that your material is .78.
And THAT worked. Many Thanks
You’re very welcome.
Easel wont allow you to carve deeper than the thickness of the material entered. So if you want to go deeper the material must be atleast = whatever final depth you want
