Nema 23 clearance on z axis
How much larger can the z axis steeper motor be? Inventables is still sold it if theirs and I found some elsewhere but they are 5 mm longer. X and Y aren’t going to be an issue, but not sure about Z.
You can go as large as you want. If it is too big to fit, many of us simply install the Z motor upside down when we upgrade to larger motors. I wish I had a better picture, but here you can see it upside down. There are spacers between the motor and the original mounting holes. Works great.
5mm longer should be no problem using the standard motor orientation.
Awesome. Thanks guys
