New Did it carve OK screen
Could we maybe do away with the extra window that was added after the did it carve OK screen? If you answer everything is fine , it says ‘that’s great’ or something similar. Just an extra step that isn’t really require
Also there are two words with no space in between on the Did it carve OK screen.
As mentioned earlier, here is a screenshot. Should be a space between provides and better.
Hi Debbie & Steve,
That typo will be fixed and the 2nd screen will be removed momentarily.
Jeff
Thank you! Much better without that last screen.
