I noticed you can update the Easel driver. I am not using the X-controller should I still update the driver? If I update will I be able to set up a z plate or do I need the X-controller?
I’m using windows 10 for my x-controller with easel driver ver 0.3.2 and Grbl 1.0 C
and work fine with probe.
I had to update as easel would not see my machine.
So if you have the older controller rest easy the new driver works.
