I’m happy to announce a couple of new editing tools to make it easier to create designs from within Easel! These are available to everyone as of now.
First is the return of the “pen” tool, but this time it is really useful! Enable it and click to drop points. Double click the first or last point or esc to get out of pen mode.
Once you’ve made a shape, you can edit it by clicking the “Edit points” button, or just selecting the shape and hitting E. You can move points around, turn a sharp edge into a curve, etc. Pro tip: hold Shift while dragging a points curve handle to keep the handles mirrored.
One caveat right now is that you cannot add new points to a shape yet. We are working on that now.
That’s good to know. I only tried the square and circle.
I also really like that double clicking when placing an end node allows us to make open shapes (e.g. lines). That’s really opens up a lot of projects that were inaccessible before.
Are there any plans to add some form of grid snapping?
Hi, I really appreciate the new features, however I encountered an odd problem today. I created some SVG files in Inkscape and used easel to generate the Gcode and exported it. I run it through GRBL controller which has always worked great but today whenever I would run a program the machine would stop at the first node? have the new features altered how the Gcode is generated?
Thank you
@BradT can you please explain more about what you mean by some form of grid snapping? The tool has orthogonal snapping. How do you want the snapping to work?
@Andy4us are you thinking that you would enter a value or combine your idea with @BradT and by snapping to the grid you instantly get precise dimensions?
@Zach_Kaplan we can make circle, but not part of like a chees part, or a pie, pizza xD duno the name in english sorry
it will be verry usefull to be able to make a part of a circle with fixed radius and angle, or point of start and point of finish and radius value. like if i want u draw a precise parenthesis like this -> (
or a quarter of circle “outlined”
for the moment i use the fonction “combine” to “erase” the part i dont want… but many times it goes realy messy =(
