New Sequence Boards
I created a brand new design using pocket cuts filled with epoxy resin on a piece of walnut plywood I had leftover from a project. I experimented with polyurethane as the finish as I typically use lacquer.
I’ve designed a different board for each of my daughters, the next board in progress is a hexagonal shaped Sequence board and I’ve included a test cut. I really like the relief cut. For some reason, the depth seemed increase as it worked its way up the board, I’ll have to check to make sure the wasteboard is level, but its probably more related to the fact I didn’t clamp it down as evenly as I normally do. My previous carves have not had this problem.
