Good morning,
I am new to the CNC world and have made several projects that have turned out great I have been asked to try doing some work with our local PD that involves carving the badge. I have several photos of the badge and need to transfer them to a SVG file or on that I can use. Any ideas? I will also need to modify the badge from time to time to change the Rank, badge number and even add a black ribbon.
thank you for your help
google jpg to svg.
If you can get a svg if the badge from the department, that would be ideal… I would still use inkscape to do the changes for badge number, title, adding ribbons, etc.
I’ve done a few from image trace and the adding text using inkscape text on a shape shape function
It isn’t the easiest task, but its doable…
this might help?
@Ken4 Is that for me?
I’m sure the OP doesn’t need RSO.
I was providing an example of what could be done with an image trace of a badge.
it’s for whoever would like to use it, or it can be google captain deputy badge
Thank you for your reply
thank you for your reply
Found this guy on Facebook, typically $20-$25. Files are perfect when I get them. He is overseas everything through Messenger, PayPal, and email
