Just got done putting the x-carve 1000 together. Try to run the easel setup and can’t get the motor to jog. But the z -axis motor will just move at random. All the homing switches work when I check them with my finger along with the buttons on the front. Not sure what the “door” message is about, no door on it. lol…
Maybe this will help from the machine inspector
Machine Inspector
Firmware Version: Grbl 1.1g
Easel Driver Version: 0.3.18
State
door
Machine position
X: 19.050
Y: 0.000
Z: 140.780
Work position
X: 19.050
Y: 0.000
Z: 140.780
Homing Switches
Check the switches & buttons status below. means switch or button is pressed, means switch or button is not pressed.
X
Y
Z
Pause
Run
Soft Reset
Z-Probe Status
No contact
Easel reports when the probe is not plugged in, or when the probe has been plugged in and the leads are touching.
When the probe is plugged in but leads are not touching, Easel reports .
Console
Show status
close
[MSG:Check Door]
ok
ok
error:2
ok
error:1
error:20
ok
ok
ok
ok
ok
ok
error:1
error:1
ok
error:2
ok
error:1
ok
error:2
ok
error:1
error:1
ok
ok
ok
ok
ok
[MSG:Caution: Unlocked]
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
[MSG:’$H’|’$X’ to unlock]
Grbl 1.1g [’$’ for help]
ALARM:3
error:20
ok
ok
error:1
error:1
error:2
ok
ok
error:1
error:1
error:2
error:1
error:20
ok
ok
error:1
ok
ok
error:2
error:1
error:1
ok
ok
error:1
