Looking for some tips or suggestions on what size X-Carve I should get. What size X-Carve are you using and the common size projects you are using it for?
For the beginning, I think I will be making more toy size projects (smaller than a breadbox) but I also know that I would like to try some detailing on rocking horse I need to make. From there signs, prop making, and who knows what else. I am fascinated by the furniture pieces too.
Initially I am was thinking of the bigger the better. However is going oversized going to be worth the extra expense? If I started with the 500, are folks upgrading the rails to build a larger unit. From roaming around youtube, looks like most units that Inventables sent out to the reviewers were the 1000x1000, but the projects shown are using 1/4 of the abilities.
Any thoughts are welcome. Thanks
~Ryan
