I am trying Easel Pro while waiting for my CNC machine to come (Shapeoko Pro XXL). I am trying to design coasters with an imported logo. I have set the material depth to 0.25 inches, but it doesn’t seem to update. I have attached a screenshot. The thickness is still at 0.5 inches at the top and appears to be 0.5 inches in the preview. Also, how long should it take to cut out a simple coaster like this? Thanks!!
If you have something set to cut through .5" material or deeper than the thickness of material you’re wanting to use you will need to set that the correct depth before it will update.
Slide it down to .25 or less
Russell
That did it. Thanks!
