Newbie - needing help with SVG issues
Any tips? My svg is beautifully symmetrical in Illustrator, then looks like a mess in Easel… I’m new to creating svg files and even newer to Easel.
What settings are you using when you export? In the SVG window, set the decimal places higher. This is my normal SVG settings:
i don’t use easel but it looks like you had easel convert a bitmap version of your artwork (+ bad settings) to vectors instead of just importing the vector file.
but I might be totally wrong.
Thanks! A long google search also lead me to this conclusion and it solved my issues!!
