I am a newby. Sorry for the simple question. I am cutting some small script text into a piece of solid wood. What is the ideal cut depth for the text?
Thanks in advance.
@SteveDryer, what are you planning on doing with the text? Fill it with resin, V-Carve, nothing or paint?
Hi Steve.
Thats not the easiest question to give a straightforward answer…
It’s going to vary based on material, size and desired look. If the design has thin walls, keeping them short will help prevent chipout, but also using a vbit will also help, as it tapers the walls, giving it a stronger base…
Then theres also desired looks.
Ultimately, it depends and I dont have a specific go-to for every project, it varies constantly.
