Can I change the colors or do I have to use the Black/White/Gray Scale?
I use an old computer in my shop to run the easel program, It walks you through the set up process and which bit you are using along with using the probe to set up the bit depth. A lot simpler that using SD card. The different bits will layer down and cut the depths as it goes. Highest to lowest in the whole design
