So something changed recently and I don’t seem to be able to add another pane (or whatever we call the other ops in easel) at the bottom. Some of my projects have the + sign to add another op, but most do not. It’s obviously not critical but makes organization way easier.
Oh I should point out it’s not even there at the bottom of the easel page. Some jobs have it others don’t so it’s not a browser size issue. New projects don’t have it.
There should be a small arrow at the bottom left of the page which will open the workpieces.
Russell, how do you do the screen shot and the red circle?
Phillip I took a screenshot of Easel, right click on the blue bar on top of Easel, then scroll down to Take A Screenshot, then click on the area you want to copy and adjust the square. Then once I copy the screenshot I paste it into CorelDraw and add the red circle and arrow. I’m sure you could do it in Inkscape. I will try it
I use SnagIt which can do that as well
Snipping tool also works in Windows.
