When prepping my file and cutting I never saw the black dot at work zero, or anywhere. It ended up cutting a little off centre.
I am using a 3018 DIY machine. I turned on my machine, edited my file a bit, pressed carve, manually jogged the machine to the start position i wanted. Everything was measured properly but for some reason it cut off centre. I am not sure if this was related to my not seeing the black dot at 0,0.
I am very new so any help is appreciated!
