When I select a new project or even an old one I don’t get a de[th of cut selection/ All I have is the Carve button which only shows me the cut depth each pass. Does the same with any bit I select and I can’t find anyware to setup depth of cut
Highlight your project then select shape on the menu and you should see a place to set your depth.
select one or more design elements, then the “cut” tab on the popup shown here, then you can set the depth via this slider or this data entry box
Thanks I see now I have to have an item in the project to get the cut settings.
I did a grid on my Silverback spoilboard and all went well.
Thank You all
