hello, Im having trouble when i make a design and go through the steps to carve, I then turn on the spindle and hit “carve” and then i get a prompt saying " no project to carve" . anyone else having this issue?
Does it show anything in the simulation side when you run it. Most likely your bit is to large for what you are cutting. Try putting in a smaller bit or a v bit and see what you get. Also welcome to the forums.
Sometimes it shows it on the a simulation side , Sometimes not. I will try changing the bit size. Thank you!
