Hey there all,
I have run into an issue in doing a commissioned project for a fundraiser for the Ukrainian Army. When I have the message in anglicized Ukrainian, it carves absolutely fine, no issues, however when using the Ukrainian Cyrillic version, it seems to not recognize this at all and won’t generate a toolpath for the letters. Any one have any ideas on what could be causing this?
For reference, I am carving into soft maple with a 1/8th roughing bit and a 20 degree V-bit for the detailing. I have tried to switch to 1/4, 1/16, and a 1/32 bit for the roughing as well, but still no toolpaths are generated
Can you please share the easel project displaying this issue. the 2nd half of this shows how to share a project and where to copy the share link from: Simple Method - How To send a friend your Easel Project - YouTube
thank you.
Yes, that does seem to be an issue. Only two of the included fonts support Cyrillic. Those fonts are Amatic SC and Montserrat. See if you can work with those.
If not, create your text as a graphic, convert it to an SVG and then import that.
Thank you very much, I was using Livvic but once I changed it to Podkova and the toolpaths were created.
I did a test and made a list of all the fonts that are usable with Cyrillic text by installing all available “Pro” fonts and running down the list. Those with a star beside them carve some Cyrillic characters but not all of them.
In no particular order:
Amatic SC
Monserrat
Alegreya Sans
Alegreya SC
Alice
Anonymous Pro
Arimo
Bad Script
Bitter
Caveat
Cormorant SC
Cousine
Cuprum
Fira Sans
Forum
Gothic A1
IBM Plex Mono
IBM Plex Sans
IBM Plex Serif
Kelly Slab
Kurale
Literata
Merriweather
Nanum Brush Script*
Nanum Gothic*
Nanum Gothic Coding*
Nanum Myeongjo*
Nanum Pen Script
Noto Sans
Noto Sans HK*
Noto Sans KR*
Noto Serif JP*
Noto Serif KR*
Noto Serif SC*
Nunito
Open Sans
Oswald
Pacifico
Pangolin
Play
Playfair Display
Playfair Display SC
Podkova
Poiret One
Prata
PT Mono
Roboto
Roboto Mono
Roboto Slab
Ruslan Display
Russo One
Sawarabi Gothic
Source Code Pro
Spectral
Ubuntu
Vollkorn
Vollkorn SC
Yanone Kaffeesatz
