I had a couple failed carves (I blame myself, F360, etc). I finally things sorted out (imported g-code, used the post processing file, allowed Easel to add g-code, etc) and got one to go through but it looked like it change position partway through and shifted the remainder of the carve. Now homing won’t work and it keeps bashing into the left side of the machine.
I somehow skipped a tooth? How does that even happen? Even if I did it should still hit the limit switch… going into machine inspector it shows the Y limit is triggered but not the X.
I have an email into support… but any suggestions in the interim?
