Inventables Community Forum
[NOW LIVE] [new feature] G-code sending through easel
I probably have an “other” to try :wink:
@Andy4us Done!
Lol awesome, thanks!
Which program are you using? Can you attach the gcode file you are trying to import?
Judging from the error message, I would check to make sure that your origin point is set at the bottom left corner of the material. This is a limitation that we have to think about some more, but let me know if doing that helps.
It borked on a file from estlcam. Remember to tell who ever programmed it that humans normally start at line 1, not line 0 , so when it generates the error message to add one to the line number :wink: It’s complaining about line 8 which is blank space
Hahaha great catch!
I’m going to create a new topic for each other CAM system so that people can discuss what it would take to conform to the spec separately. (Here is that topic [gcode import] estlcam)
Aspire…This is for a 0.25" endmill
Easel - 3D Roughing 1.nc (265.7 KB)
I would like to try this please
I’d like to try it as well, I’m a Fusion 360 user.
Thanks!
@LynMcneese Done, also you shouldn’t post your email publicly like that :confused: (i removed it for you)
@MathieuGlachant You got it!
I would love to have access, I have had problems with both USG and chillipeper but easel has worked great.
I’m a new X carve user, 20 year user of autocad 2d. I’m migrating to F360 and would love to try this feature. I’m having a terrible time with the art based software. Easel, Inkscape, etc
Rob
@RamonQuinones @RobertConrad Done and done.
It is odd, the finishing pass loads fine…
Haha we just now pushed a fix! I was able to load the one you posted just now.
Sweet!!!
I had a boundary offset…that must have pushed it just below 0 on the X-Axis…
Yup. We actually just removed that constraint. The constraints still apply for Carvey (which has a fixed area and automatic homing), but it didn’t make as much sense for x-carve. Hopefully we’ll be able to improve the flow for setting a centered zero in the future.
I use Fusion 360 and would like to try this feature.
Awesome
