I am starting to use fusion 360 and would like to try this feature.
I would also like to test this feature.
I would like to try this new Easel G-Code software.
@KellyYoung @StephenDaniels @ElliotD_Jesch @Rcannon95 @WeylandBailey Y’all are in!
I should have V-Carve Pro by the end of the day tomorrow, and I’m currently using Fusion 360. I’d like to try sending G-code through Easel - that would be a great feature.
Testing our MeshCam now, I’d like to check out this feature.
I’d like to try it!
Out of curiosity, why does easel adhere to single digit G-Code, GX, instead of GXX? I was talking to Jeff from @picengravertoo about importing PicEngrave G-Code into easel and I had to manually edit each file to import it into easel.
Please I would like to try it! This is a godsend for me
Hi All,
I tried with Meshcam today.
Mixed success, did a small test with a coaster 100mmX100mm
- If I export the file in mm (from Meshcam) and then open via Easel then the piece seems to be converted to inches (appears super small)
- If I export the file in inches (from Meshcam) it seems to work OK
Would be nice if the mm work as it was a pain converting to inches.
Cheers,
Trent
I would like to try this as well!
Can I get access to G-code importer want to try and bring v-carve into easel
Had problems. I created the g-code in MeshCAM and imported it as directed. It produced a very nice graphic. I started the project and it just stopped running after about 2 minutes. I took the same g-code and put it in universal g-code sender and it ran flawlessly. I know of one error I made: I left the rough pass checked and just entered the same tool for rough pass and finish pass. That may have been the issue. Unfortunately it will be a while before I try it again because mistakes are expensive. It would also be great if you allowed a tool change in the code.
I am quite a fan of Inventables. Not easy to get the results of a $20K CNC mill with $1,500 worth of parts and software but it is getting there. It is not for the faint of heart.
Thanks Zach!
@Dave2 @AK_Eric @JeffreyLandrum @EmilyMaker @JasonBastedo @BobMarinoff Y’all are in!
Could i please be added to the list of being able to import G-code into easel?
I will be trying to use Bobcad 27. It has its own editor. Can not think of the name of it off hand. It has many different types og gcode depending on the controller. I just got my xcarve running tonight but not with bobcad. I will have to try things out in a day or two. I will let you know the name of the editor soon.
I’d like access to try this
I would like to have access to this feature. Thanks
