Good day all,
I am planning to cut a large ‘5’ using one of the standard texts. Profile only, but I need to add a small tag to the bottom of the number to enable fitting to a base plate. How do I prevent the cutting of the portion of the 5 at the tab.
create a box the size you need and combine the two, be sure to set your profile to cut on the outside
