Someone can help please,How do you add obs wood in library material in easel pro
You can not add your own wood. Simply select a type of wood with similar properties and use that.
The only thing choosing wood type (or plastic/metals) do is to suggest feed rates/depth per cut. After some use you find you machine sweet spot and go with that.
Thanks you so much
