HEllo I am new ti Easel and I am working my way through the set up It has a spot for Openbuilds but the two choices for controler I do not recognize, I am using the OB black box, which do I select? Thanks in advance and is there anything else I need to know,
Easel assume a GRBL type controller (which gshield and Xcontroller is, so is the BlackBox IIRC) so just state “XController” during setup. You may need to tweak some settings either for the stepper drivers in the BB or the GRBL parameters but that is next step stuff
