Hello everyone,
I am going to be attempting to extend the Y length from 1000mm to 2000mm, I need 24" X 48". Just to let everyone know in advance I do not use a router on it any more, it is strictly for laser engraving (cornhole boards)
I will video record my building process and post it once I start and give updates on how it is working.
Build thought:
I purchased 2 new 1000mm maker slides and 32ft. of GT2 - 6mm belt
I will use the two screw holes and most likely drill them out and place a piece of aluminum rod to keep them lined up
I will use Aluimiweld to braze the joints, from reading online this will be a very strong joint.
Brackets will be used to stabilize the Makerslide to prevent flexing
For the bed I am thinking of just using a sheet of 3/4" or 1" plywood with underside bracing instead of using 20/20 extrusion and mounting directly to that.
Does anyone have any preliminary thoughts on why this could or could not work?
Thanks
