Every time I change the bit to anything bigger than 1/16 i get a message that there is no image available. I would like to cut this with a 1/4 but will settle with a 1/8.
Wood thickness will be close to 3/4 and it will be a complete cut out all around.
Please see attached project:
Your line consist of two lines.
- Click once on your design
- Press E and you´ll see a bunch of dots appear (nodes)
- Select one of the inner nodes and press Delete, press and hold Delete untill all the inner nodes are deleted. (The inside will turn black)
- Once completed, go to the Cut meny and select Outside of path
Now your outline only have one line, and you can choose 1/4" no problem
