Overlap tabs
Hello All, I’ve got a problem with a design that has two cut outs in the middle of a board. Each cutout requires two tabs so they stay in place until the carve is completed. I continued adding tabs until there were two tabs for each cut out. This creates 16 total tabs, which is more cleanup than I want to do after the carve. My only solution is to move the tabs on the outside to overlay other tabs. This makes it appear in Easel as though there are fewer tabs in the carve. My question is can anyone confirm this will work or is there some other way in Easel to place tabs on cutouts. Hope this makes sense.
Thanks,
Mark
Nope. Doesn’t make sense. This is where you lost me.
You should “continue adding cut-outs, and assign each cut-out 2 tabs”.
Thanks for the response. I don’t know how to assign a tab. I can drag a tab along the line it appears on, but can’t drag it to another line.
If you want to, share the drawing so this makes more sense.
