Was hoping to buy a modular wasteboard kit and some new red bolts. Both are sold out.
Going through the store it appears there are lots of sold out items.
Any chance these are going to be restocked? Or is inventables going to stop supporting current machines?
I have the same question. I need 6.35mm belting and it’s sold out.
I had to call to get a new “1000 mm maker slide” for my large X-carve because they were sold out online. The mounting holes had wallowed out and wouldn’t hold the screws anymore (my fault for moving and not tightening everything back up). He found one for me, but this is concerning. I paid thousands of dollars not long ago for this system and need to know I can get replacement parts from the source.
Consider buying a used unit for parts. I see them on Facebook marketplace quite a bit. Also, if your carriage and makerslide are in good shape, everything else for the most part can be found online. Ex. Extrusion, wheels, spacers, belts, pulleys, nuts and bolts, etc.
Marketplace - Xcarve CNC 1000mmx1000mm | Facebook
Also if you are desperate, you can make your own makerslide by adding open builds V rail to 4040 extrusion.
Plate drawings are available if you wanted to send a drawing out to an online machine shop for fabrication.
OpenRail Linear Rail - OpenBuilds
Lastly these guys are in Europe.
