Pattern filling a shape in easel. diamond drag engraving
Hi,
I know that V carve can add a pattern fill to a shape but I haven’t got the money for that at the moment.
So I am trying to come up with a work around …
I have a design in easel set to a fill cut at 3mm. I want to overlay a pattern filled shape that will be set to zero depth. The carve will then only cut through where my design is set at 3mm and I will be left with a pattern fill.
I will mainly use this for drag engraving.
Any one tried this or have any patterns the can share
would it help if i add that i want to use some kind of hatch or cross hatch pattern?
