Built this one over the weekend as a prototype for future builds. The base is maple, the stands are .093 acrylic. All design and programming was done in Fusion 360, controlled with ChilliPeppr. 3/32nd bit for the acrylic slots, 1/4" downspiral for all other cutting. The outer edges were lightly sanded with 240 to remove any remaining cutter marks, the finish is semi-gloss lacquer, after sanding the flat faces with 150 and 320 with the random orbit sander. (I have a Shelix cutter in the planer, that does an AWESOME job but leaves a tiny bit of a ‘wavy’ surface that needs a light sanding to eliminate)
The acrylic was cut with my laser.
