I’ve recently installed a Triquetra Touch Plate. I’ve been using UGS to send the GCODE for the touch sequence. It works great except for having to manually zero the axis in UGS after the touch sequence.
I tried Picsender to give it a test run. It works very well, except for the carriage speed when I manually tell it to do a move (to set bit in position for touch sequence). The carriage moves VERY SLOWLY in very small steps. Do I have to initially send some GCODE commands to tell the carriage to move faster?
I’ve had my X-Carve for about a year, but I just started exploring the mysteries of GCODE.
Note: the Triquetra Touch Plate is a fantastic investment. Everything works as promised. My initial pre-purchase questions were promptly answered, shipping was fast and reasonably priced, and the packaging was great (everything was separately shrink wrapped). Excellent service.
I would recommend that you change this to 255 ($1=255). That will keep the stepper motors on which will help your machine maintain its position when it is idle.
Below the gold “Mode” display and above the jogging controls, change the feed rate to something like 100 inches/m.
That should increase your jogging speed. Play around with that setting to get the speed that you want.
