Hey everyone,
I recently bought my X carve and have only a few cuts under my belt. I am already running into positioning issues. I have homing switches and the dust collection attached. Prior to the cut, I just Easel for proper dimensions and units. When asked, the X carve will go to my home position no problem. I use a probe for the z axis too. When i go to carve i will use the z probe and use my home position as the (0,0) position. When i go to cut, the x carve will begin a little too far “up” the y axis and a little too far to the right on the x axis. When cutting, i have no seen a noticeable change in the cut itself. Additionally, when trying to cut out and object from the wood, the z axis does not cut all the way through the wood (i’ve even set the depth slightly higher so it SHOULD cut deeper than necessary. When the cut is finished, i expect the bit to move back to the original home position, however, it does not. (it actually comes two 'Units" shy in both the x axis and y axis.) Any help would be appreciated
