Easel successfully produced gcode for the Maslow M2, however the project (4x8) is centered on at the 0,0 position instead of the lower left hand corner.
How to fix?
How to fix?
You can move the design in easel to be centered at 0,0.
Select all and then using the popup on the right you’ll need to select the center if the 5 dots and then type x0 y0 it’ll move the design to the 0,0 position.
3/4 of it will be off of the material showing in the preview, but this is the only way easel allows alternative work zeroing. If you simulate the project it will still show 100% of the toolpaths
This worked.
Thx
