Post-Process Fusion360 Z comes out too high
Looked / Lurked on here, but didn’t seem to find a solution.
This here seemed like it:
But I still came up empty
I have a model that I want to do a 2D mill on. It’s .75" thick, but when I gen the toolpath and post process, looking at the Z in the config:
G90G94
G17
G20
(TOOL/MILL,0.125,0,0.5,0)
(STOCK/BLOCK,9,5,0.75,0, 0, 0)
M9
T1M6
S12000M3
G54
M9
G0X3.5739Y2.4796
Z1.35
Z0.95
G1Z0.8625F25
X3.575Y2.4807Z0.8564
It’s coming in way high. Which is also somewhat confusing as the bit will touch off… then retract way above anything in my entire model.
I’ve tried messing with the cam settings, even moving the origin and pulling the entire body into a new component group (internet advice) but still getting the same result.
Any help is appreciated. Thanks much
Doh, think I got it, sorry for the post. I gotta start working on this stuff when I haven’t been at work for 14hr.
I am still experience the same problem, can you please let me know how you figured out the problem
I really appreciate it.
shawn
@ShawnKazemzadeh Can you describe what your problem is?
Hi:
thank you for a quick respond, I use the wastebord modle to set up my model on carvey’s wastebord
created two boxes 6" by 6" and thinness of .7 " inches use this as my stock
then the second box same sizes except the thickens is .6" where there is my model on it
I created the post processor with fusion 360.
my z starts fine from the smart clamp goes done right but all of the sudden goes up and start at lease 1" above the surface and starts carving on the air.
I don’t know what to do to the G code to bring the z right on the surface
ShawnKazemzadeh2m
Hi:
Can you share your Fusion 360 file?
1001.nc (2.1 MB)
G90G94
G17
G20
(TOOL/MILL,0.0312,0,0.2547,0)
(STOCK/BLOCK,6,6,0.71,0, 0, 0)
M9
T1M6
S12000M3
G54
M9
T1M6
GRBL does not support M6. It returns an error,
Your entire job is above the Z0. Can you share the actual Fusion 360 file? My guess is that it is an issue with the way you set up the job.
Thank you so much, here is the breef description
i have
wasteboard for carvy
Opened this file
created a stock box 6" by 6 " thickness is my wood thickness .75 "
created the second box thickness is .65"
my model is on this box
placed it on zero Origin and move the boxes 5" on X and 1" on Y axis
creat new set up in Cam
choose the face contour
Choose the 2D adaptive and
created the post processes
here is the file
ToBePosted v1.f3d (1.4 MB)
also same file with G code I posted here
1001.nc (1.5 MB)
OK, the Carvey will automatically set your work zero at the top of the workpiece, not the top of the wasteboard.
Create a point .75" above your current WCS, and use that as your origin in the CAM setup.
Do you have your stock under the “smart” clamp?
Thank you so much
.75 is my stock and .65 would be my model
I will try to do it tomorrow and I think what you are saying make sense
so sleepy struggling with this
I will write the result tomorrow in my office
thanks again
I think that:
You dont need to define stock as a solid in the Model enviroment, this can be defined under
CAM → Setup1 → Stock
What you have done is with the modelled solid is to set the facing operation to match its face, not the design face. In other words, they wont meet :wink:
Changing to the above will remedy that I hope.
If not - which post processor are you using?
This thread might also help - Fusion 360 to Carvey - Smart Clamp Origin? - #6 by EllaS
Also, using a 1/32" end mill for facing operation is highly time-consuming, machine time estimate 5h45min.
Using a 1/8" if the Carvey can take that (you dont mention material to be routed) will remove 5hrs off that time… well worth the hassle of changing tool :slight_smile:
Thank you so much for for important inforrmation. I am using fusion 360 and use easel that came with my carvery. Going to try the advices and giving you the results
thanks again
I tried all the advices, I keep getting errors that my model is under the smart clamp. Which is not.
can someone be kind and creat the post processor for this model that I can carve it with Carvey
thank you
I use fusion 360 and carvey to creat the post processor and use easel to transfer the file from fusion 360
model2post v1.f3d (836.3 KB)
@ShawnKazemzadeh I can’t generate toolpaths for you to run without knowing a lot more about your project and setup. That said, all you need to do is set the stock and the work origin correctly.
thank you so much
it worked great
thank you for the great video that you created,
i really appreciate it alot
have a good one
