Power went out while cutting!
While cutting a design, the power went out for a quick second. The spindle kept spinning but easel ended the project. Is there a way to continue where I left off? Or how would I get back to the exact starting point to re-cut it?
Is there a way to get back to the exact starting point of where i started from? At the moment i haven’t moved anything and the spindle is off, but where it stopped during power out.
Requires a little planning ahead of time, but you could use G28 or G30 to hold your work zero position.
If you haven’t stored your position prior to starting the carve this won’t work.
