Preprocessor v carve
what is a good preprocessor to pick from the list "V Carve "
Do you mean Post Processor? If so there is an Inventables specific post processor.
You can get it here:
Larry M… thanks for the info now I need to fine some way to import it into the v care list I tried a few different ways still says it will not except the file
@BobMarinoff
Here’s where mine is:
C:\ProgramData\Vectric\VCarve Pro\V8.0\My_PostP
If you put the post processors in this directory they are the only ones that will appear in your list.
You may have to look around a bit on your system if you installed it differently than I did.
