I am looking for an Illustrator / Coreldraw / Inkscape / SVG file that has the dimensions of the wasteboards for the X-Carve Pro. Alternatively, just the exact center spacing between the threaded inserts would be helpful.
Many thanks
Tim
Many thanks
Tim
Did you ever get this info Tim?
Hi Jonathan, no, nothing yet.
I called today to get this information as well, still nothing. If I hear something I will let you know.
Thanks v. much!
That is brilliant, thanks, Bradley.
Also for overall dimensions of a single wasteboard (the 4x4 has two so double the y-axis length.
X: 1363 mm
Y: 610 mm
Z: 18 mm
Appreciate everyone’s help, so feel free to use or modify the bump-stop rulers attached. Should work on any laser including GlowForge (for the smaller ruler), and sets up nicely on the X-Carve Pro.
Once you’ve affixed to your washboard, dial in the XY start position and make a note of it - just slide future projects into the square and it’s a quick start each time.
