The title about says it all. I installed my new X-Controller today. All tests seem OK, except the probe. I have both the new Inventables probe that I got with the upgrade package and the Triquetra probe. I had previously used the Triquetra connected to the A5 pin. Worked great. I’m assuming that the wiring of the Triquetra and the Inventables probes are that same (just wires, no resistors, etc.).
I installed the Triquetra probe wiring directly into the PROBE and GROUND connections on the X-Controller. The Easel probe install test does not see that the connections are touched. The Picsender probe command does not see a contact, nor does running the Triquetra zeroing code.
I tested continuity from the X-Controller connector screws in both PROBE and GROUND to the ends of the probe wires. All is OK. I have not yet calibrated the steps.
Grbl 1.0c [’$’ for help]
<Idle,MPos:0.0000,0.0000,0.0000,WPos:-1.0000,0.0000,0.0000,Pin:000|0|0000>
ok
[G0 G54 G17 G20 G91 G94 M0 M5 M9 T0 F0.0 S0.]
ok
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=115 (status report mask:01110011)
$12=0.002 (arc tolerance, mm)
$13=1 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$30=1. (rpm max)
$31=0. (rpm min)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
ok
Done
