Hello All,
Is there any way to set the probe height to a certain dimension? For example, I have lots of projects for 1/2 Birch and i would love to not always probe the 1/2 Birch. Any way to skip or have a set probe height?
Thanks!
as long as you don’t change your cutter and have same thickness of material. You shouldn’t have to probe
You can select “use last” for x,y,z if you select manual method instead of probing, but what Ken said holds true, if you swap bits you’ll have bad results.
But using other gcode senders you have more options that aide in this process.
Thank you, both! Something so simple. Thanks a bunch!
