Problem importing G code from Fusion 360 to Easel
I have just started trying to Fusion for CAD and CAM and than using Easel post processor to bring into EaselMy issue is half the work piece is not on the grid. How can I shift the piece over so router does not slam into switches? I am guessing my issue is resides in my CAD setup?
Correct.
In F360/CAM you need to define start point (0,0,0) under the Setup tab.
By default it is stock center, you need to use corner point for what you try to accomplish.
