Imported svg and generated tool path and set to cut rough cut went fine went to do finishing pass and bit higher thrn the projectvim working on
how about sharing your project so we can help you better then assuming what the issue is?
Hey Dee I am having the same issue. Would love to know if you found a solution. This is my topographical project im working on
what model CNC are each of you using??
IF it’s the model I suspect (new X-Carve) than your Z axis may need to be lowered…
If it’s something else, then I’d verify the Z probe thickness is entered correctly AND that the bit isn’t slipping up into the collet AND that the workpiece top is parallel to the gantry…
Also I noticed your Finishing bit is very large, and the stepover larger than I’ve ever run a finishing pass… you may want to review the preview before actually running this…
Here’s some info to check out about stepover and bit size:
https://www.cnccookbook.com/cnc-stepover/
and your carve will have all these bumps due to the bit size and stepover…
