So I was carving a piece tonight and the machine went haywire. I removed the piece I was cutting and checked X, Y, and Z axis. On the X, I get this. Any help would be greatly appreciated
I would check v wheels and belt tension? move your carriage to right take a look at the teeth on the belt. possibly warn and needs replacement
Just checked the belt and no teeth missing
check wheels and belt tension
It was the servo on x. I turned it off completely and manually slid it on x axis. Powered back on and the noise went away. Weird
It is definitely jumping teeth on the belt. The tension may need adjusted…
